yamaha fl-01 flanger irregular woosh
Started by 9 volts, August 15, 2007, 06:56:41 AM
9 volts
Hey there, My yamaha fl-01 flanger seems to have an irregular woosh (like the third woosh is longer than the rest). It has four trim pots inside which I've attempted to adjust with no improvement. I did a voltage check on the electro caps and they seem ok. I don't know what voltages should be going to the ic's and don't have a schematic. Anyone got any suggestions? Thanks
Dai H.
might have been the same as the Korg FLG-1 IIRC, which there is a schematic for on the internet (someone was nice to put up a bunch of Korg schemos some time ago, and basically they appeared to be the same as a series of Yamaha efx.).
9 volts
Thanks I'm in the process of trying to find the Korg FLG-1 schem. It seems like there are two trim pots that control the frequency peaks that greatly influence the whoosh. I suppose I need to find out how to correctly adjust them. Thanks again. ps. pm me if anyone has the schem
Dai H.
I can send a copy if you are not able to find one.
