PCB Layout Problem aka A Boost That Doesn't. HELP!!11!
Started by railhead, August 17, 2007, 06:34:47 PM
railhead
Still working on making a really small, custom AMZ Boost PCB -- and I would have bet money I had it figured out -- but when I engage the pedal, minimum volume equals silence (which it should), but maximum volume equals unity. I swapped out the J201s and I get the same result, so the only thing I'm left with, is assuming I screwed-up my new PCB layout. Here's my arrangement (looking down at the component side):
Here's a list of voltages:
Q1
D: 9.25
S: 5.36
G: 4.44
Q2:
D: 5.37
S: .650
G: .2
I don't understand why Q2 isn't getting much juice, but that's because, admittedly, I don't know a whole lot about this stuff. :)
What else do I need to check? Did I screw up this PCB layout somewhere? Here's a link to the schematic file. All my solder joints are good, I'm not getting any shorting between traces, etc.
This thing has been totally kicking my butt for DAYS...
railhead
mars_bringer_of_war
Be sure the jfets are oriented properly. That would be an easy mistake, and looking at the layout, that may be the problem. Try flipping them.
I will quietly resist.
