5 Millenium bypass on the same PCB, issues?
Started by arma61, February 25, 2008, 01:09:37 PM
arma61
Hi
so I've (I would like to have!) 5 FXs into the same box, on 5 different boards, can I have 5 Millenium bypass on a single PCB sharing +9V and GND like in this picture
Will this affect their way to work ?
Thx
Armando
"it's a matter of objectives. If you don't know where you want to go, any direction is about as good as any other." R.G. Keen
arma61
Auke Haarsma
If the only thing they share is GND and +9V then there will be no issues. It will be like what I'm doing in my multi-fx unit, although I don' thave them all on one pcb, but they all share the sae GND and +9V.
Good luck!
arma61
great ! thanks Auke,
Quote from: Auke Haarsma on February 28, 2008, 06:21:19 AM
I have the same, one board per Mill,  in my multy box you see as my avatar, and I have an led that's always on I though this could be the problem, that's what I was worried about. So may be the problem is on the relevant fx not on the millenium.
Armando
Auke Haarsma
you're welcome!
In my experience, if the led stays always on it is most likely that the BS170 is defective.
