Distortion-Octaver or Octaver-Distortion?
Started by GREEN FUZ, September 06, 2007, 02:54:47 PM
GREEN FUZ
Quick question. I'm preparing to box a Red Llama and Green Ringer in the same enclosure. In series. Popular wisdom seems to suggest the distortion would go first in the chain but I thought I`d seek the forum`s thoughts and views before committing.
I have a board with a Distortion+ followed by a Scrambler.  Sounds decent.
The thing about both octave up and down is that both lean towards having a fairly steady input signal, albeit for slightly different reasons.  Just about all distortions will introduce some compression of their own, and also provide a sustained output signal, so that moves in the direction we want.  On my own Green Ringer, I stuck a booster stage in front, and that improved performance.
So, on both counts, you probably want to go distortion->octaver.  Just try to keep the tone smoothed and the treble tamed.  The other thing to consider is that the Green Ringer, like just about all octave-up units of its type, generates a lot of non-harmonic components, especially when you bend notes.  Trust me on this one that you would rather generate non-harmonic derivatives of the lower-order harmonics in the guitar signal than generate harmonics of the non-harmonic derivatives (sum and difference signals).
GREEN FUZ
alex frias
The Mr.Hammer answer is very well thought and makes a lot of sense.
But experimentation has given me a lot of interesting results... But not everytime.
Some perverted use of guitar fx's can be adictive, so be careful with those insane boxes stream.
I´ve tried an octavia style box before and after some distortions. It´s good after fuzzes and overdrives, but a serious killer before some kind of overdrive boxes, dirty channel tube amps and amp simulators like SansAmp line of pedals.
Pagan and happy!
g3rmanium
Quote from: GREEN FUZ on September 06, 2007, 02:54:47 PM
With the Green Ringer I like some distortion first.
Sound clips Arion Tubulator -> Green Ringer
Call me Johann.
alex frias
I agree with you as some overdrive before the Green Ringer is a must. I've used a TS/FullDrive before it with excellent results, but IMHO, the RM Octavia is great with a mild good overdrive after it, it really screams out and the sustain is very rich in coloration.
Pagan and happy!
