HELP.. my power booster doesnt work.
Started by xypher, September 15, 2007, 01:46:43 AM
xypher
I built this today, but it doesnt work. Only the bypass works, but the effect doesnt. Im not sure if i am using the correct switch. Is there a way to check if the switch is the correct one?
http://smallbox.zeonhost.com/projects/lpb1/index.html
Here r pics:
foxfire
the switch it's self looks fine. you could try wiring it up without the switch to see if is a problem with the switch or somewhere else.
burnt fingers
It looks like mayb the input and output jacks are wired to the wrong lugs of the switch.
switch those two around and see what happens.
Rock and Roll does not take a vacation!!
www.rockguitarlife.com
My Music
xypher
Ok, i'll try.
Anyone has any other suggestions?
