PT-80 1uF caps
Started by Aharon, September 17, 2007, 12:22:27 PM
Aharon
Can 1uF NP electros be used instead of polys?.
Aharon
Aharon
Joep
sure, although they might have a negative influence on soundquality. Small Bear has 1uF that fit into the GGG PCB.
Personally I would (and I did) choose the poly's.
Good luck!
Joep
Aharon
Thanks joep...........I just placed an order at Small Bear for the smaller panasonics........
Cool  :icon_mrgreen:
Aharon
Aharon
igor12
I use cheapo 1 uf ceramic caps and it sounds fine.
