Easyvibe + 3pdt
Started by modsquad, September 22, 2007, 04:20:42 PM
modsquad
Is there a layout, pcb, etc. for using a 3pdt with the easyvibe instead of a dpdt switch and millenium bypass circuit?
"Chuck Norris sleeps with a night light, not because he is afraid of the dark but because the dark is afraid of him"
Arfman
Quote from: modsquad on September 22, 2007, 04:20:42 PM
No change to the PCB. Just leave the lug unconnected that now says "To Millenium Bypass". Then use the 3rd position to connect/unconnect the LED to ground.
Here is an example of doing the DPDT part which also grounds the pedal input when it's off...
http://www.generalguitargadgets.com/diagrams/scrambler_lo.gif
Again, then just use the 3rd set of poles to deal with the LED...
