current sensing volume control [not] in DIST+
Started by petemoore, October 05, 2007, 05:59:50 PM
  I figure must be the caps in it that were reverse polarized.
  Or something else.
  Kind of neat effect, seems directly influenced by the amount of input.
  Slamming a buncha chords brings in high gain and treble [sometimes/often enough to tell that can happen I think].
  After a while all the slamming or no slamming seems to fade the gain, to a thin sound.
  Mini Booster preboost turned on for exp's.
  I've had this before where the volume is controlled by input level...sometimes, but unmistakable when it does, play along for a good while quiet, hit a few chords hard and the gain goes from like around 0 to 11.
  Just wondering, for the OT record about that type of 'effect' .. about maybe the bypass cap is varying capacitence and that would vary gain or something.
  I changed the bypass cap.
  Sounds voltage starved, could be the minibooster acting up..
  Seems to work fine now, I've swapped the LM741.
