quick amp footswitch question!!
Started by nero1985, October 18, 2007, 02:31:38 PM
nero1985
hey guys!! just a quick question...
if i build a 2 button footswitch for an amp do i have to insolate the ground? like by using a plastic 1/4" jack or can i just use a regular jack?? would it have any ground problems by doing this? thanks!!!
Pushtone
Most likely, no.
An isolated jack is not needed.
If however you plan to install LEDs that are powered from your general PSU there could be a ground loop issue. In which case, isolate the jack.
When I build amp footswitches with LEDs, I prefer to use a battery to power the LEDs to eliminate the issue.
