Millenium is not working on this circuit, what's missing ?
Started by arma61, October 21, 2007, 04:43:45 PM
arma61
Hi
I've build this Minisynth, it's working almost good, but cannot connect a Millenium bypass circuit to it, the MB dosn't work conencted to this but if I connect the MB to another circuit (DOD OD250 or ousb) it works. I've tried to put a 2.2M resistor from signal in to ground (even a 6.8M) but still not working.
what do you think about?
here the link to the schem.
thx
Armando
"it's a matter of objectives. If you don't know where you want to go, any direction is about as good as any other." R.G. Keen
Where did you put the resistor? If you put a 100k resistor from after the output cap to ground it should work, on the schematic that would be from J1 1 to ground.
arma61
Thx Slacker, you cleared my mind!, I cannot check it now but I think I connected the resistor to the input cap instead of the output cup!, this project born upside down! I'll try tonight with the 100k resistor
arma61
Slaker you saved me!, it works and I've found, as I said before, I've overlooked at the pcb and put the resistor to the input cap. Now I can finish my multifxboard (just 4 fx!) .I  was just missing this last LED.
