how to wire a transistor
Started by pardonmybass, October 21, 2007, 08:47:17 PM
pardonmybass
what is a good way to soder a transistor so it doesnt get burnt out
Pushtone
You can use sockets.
I take DIP IC machine sockets and cut them up.
You can see what I mean in this pic.
The cut up IC sockets are used to mount the resistors.
Alternatively you can use an alligator clip as a heatsink to absorb some heat.
If you can solder a point in 3 second or less (holding the iron to the point for that time) you will not burn out the transistor.
As an extra precaution, wait several seconds for the first point to cool down before doing the next one.
oh, and blow on it while you solder.  :icon_wink:
frankclarke
Hold the leads with your fingers, or use some kind of metal heatsink, as suggested above.
GibsonGM
+1 Pushtone, the 3-second rule.....
  1 Check the data sheet
  2 Observe pinout
  3 double up on your triple checking of the pinout.
  4 Heat Iron
  5 re-check the pinout while the iron heats up
  Mostly a serious Jfet Joke, but getting the pinout right is a big heat/time saver.
