AMZ Mini Booster Capacitor Question
Started by deke99, November 01, 2007, 09:57:24 AM
deke99
Hi all,
I'm in the process of building the AMZ Mini Booster and I have all the parts except for the 10pf capacitor that follows the input capacitor and goes to ground.  Can anyone explain the purpose of this cap?  What difference will I notice if I use a 47pf cap (or string 2 47pf caps in series for 23.5pf).
Any help/explanations would be much appreciated.  Thanks!!
Derek
foxfire
it bleeds some of the highs/treble to ground to keep it from getting too harsh. you probably won't noctice much of a difference swapping in either the single 47pf or the pair. if you have sockets use them so you can play around with it.
deke99
Thanks for the info Foxfire!  I don't have any sockets at the moment, so I'll probably just go for the series combo. I appreciate the help/explanation.
shredgd
Actually the function of that cap is to shunt radio frequencies to ground: this way they won't be amplified by your minibooster.
Of course, the bigger the cap (it acts like a high cut), the more you might also shunt the highest frequencies of your guitar, i.e. presence. But I think 10p, or even something more, still won't affect your signal. If it does, however, it is welcome, as it will make your boosted sound smoother.
Giulio
Protect your hearing.
Always use earplugs whenever you are in noisy/loud situations.
My videos on YouTube: www.youtube.com/shredgd5
My band's live videos on YouTube: www.youtube.com/swinglekings
