how to 'rig' an expression pedal for the Mutron Bi-Phase ???
Started by Derringer, August 07, 2011, 07:39:39 PM
Derringer
I can make a few bucks if I can successfully fab an expression pedal for a guy I know who has a Mutron Bi-Phase.
I'm hoping that I can just get away with routing the 5-pin midi cable into a Crybaby shell and solder in the proper wires to the pot.
there's a schem here
http://m.bareille.free.fr/biphase/the_vintage.htm
and the schem showing the rate pot itself is here
http://m.bareille.free.fr/biphase/vintage/mutron_biphase_sch1.gif
from this page
http://archive.ampage.org/threads/0/fxgen/001395/Re_Anybody_seen_the_sweep_pedal-1.html
I see that "Of the 5 pins on the foot pedal jack, they consist of in no particular order,
+15vdc
Channel A enable
Channel B Enable
one side of the reostat
other side of reostat (I think I spelt that right)
Shorting the +15 to Channel A or B turns each channel on induvidualy or simultaneously and I just connecting a pot across the remaining two pins will adjust the rate.
but then when I look at pics from here
http://www.....org/viewtopic.php?f=19&t=3847&p=41737&hilit=biphase#p41737
I see someone wired three and not just two connections for a pot (at least that's what I'm assuming)
any idea what i should do?
The pot in the wah shell that I have is 100K and seems to be linear
