White water slide decals. I get misscoloring. Any experience with the stuff?
Started by Focalized, November 06, 2007, 01:01:53 AM
Focalized
So I have a green Big Muff clone. And a cool design I like with the green somewhat matching the pedal color. I print it up on white decal paper and it comes out brown. Also solod black come out kind of wavy. Now I know my printer is fine. Prints the green fine on plain paper. Anyone have experience with white decal paper and know if there's any special treatment I need to do? I print out in ICM mode, meaning the colors come out more like they are viewed on the screen. Most i've printed look nice besides this MUFF mess. Ew. I can't keep wasting paper. It's expensive.  And this won't work on clear decal paper. The orange disappears.
Here's a pic with the pedal, the design from Paint Shop Pro and the printed result.
audioguy
you need to experiment with your printer settings.... like High resolution photo for the print quality, then selecting the paper type correctly. Usually I use the setting 'high gloss premium photo paper' and get perfect results... but honesty, it varies.
good luck!
Focalized
This forum moves fast....
Yeah I used a few different high settings with similar results and my ink is going real fast. I suppose I can go back to this one and save one sheet and try multiple setting for it. I'm still pissed though.
sshrugg
Are you using a laserjet printer?  I work in a computer lab, and we've got color laserjets that print beautifully, but HATE certain glossy photopapers.  It looks a lot like that when you try to use them.
If that's the case, go find somebody with an inkjet :)
Built: Fuzz Face, Big Muff Pi (Stock), Distortion + (Germanium and Silicon versions)
Focalized
No, it's an EPSON Photo inkjet. So I don't know why that color doesn't print right. The paper is inkjet paper from here: http://www.papilio.com/hps/home.php
audioguy
I use an Epson too and get perfect results after a bit of testing... As odd as it may be... perhaps its the paper. I use the stuff from www.decalpaper.com.
