....random vanishing.....
Started by makkimo, January 15, 2008, 06:06:39 PM
makkimo
hi all!
just finished the wow vanishing point 2.1 - thanks a lot T o n e G o d !!! - the seq. works well but after hours of trying i can't really find a way to get the magic random mode , when i switch it to random mode the seq simply stops and ..........nothing  :icon_redface: well i know there are many posts on this one and i've read it all but can't understand exactly the caps or res tweaking wich helps random come to life
thanks a lot
~arph
Had the same, but it was due to a bad IC (fried one of the inverters)
The Tone God
If you are sure all the clocks are working you can adjust the random length by altering the 1M/0.1uF ratio that comes from the sequence clock. More of either value will increase the length of the random cycle.
Andrew
