FET Matcher
Started by slideman82, November 21, 2007, 06:44:54 PM
slideman82
Well, I tried to compare the Fet matcher of Geofex and the one from ROG... the last one always worked, but the one from Geofex doesn't seem too... has anyone has troubles with it?
Hey! Turk-&-J.D.! And J.D.!
Barcode80
am i dense or missing something? i don't see a fet matcher on ROG. ???
Quote from: Barcode80 on November 21, 2007, 06:51:50 PM
There's notes and schematics for measuring FETs on the Fetzer valve page, I guess that's what he's talking about.
I've used the Geofex one a few times, it works fine. I'd double check you've built it correctly.
slideman82
Yeah, I think you're right.... Laaaaaaaaaaaaaaaaaaaazy stay in bed!
Papa_lazerous
I have used the FET mather from GEOfex works perfectly  :icon_biggrin:
oldrocker
Yes the fet matcher at the Geo site is the one I used.  When I need to match fets I breadboard the Geo fet matcher and start matching.  It worked great for my Phase 45.
Barcode80
yeah i just finished up a phase 45 and i went ahead and committed the matcher at GEO to vero, as i plan on building a few more phasers. good stuff.
96ecss
I did a pcb layout for the Geo Fet matcher. It works fine.
Dave
Barcode80
oldrocker
The Microsoft mouse jfet matcher is really cool.  Great idea.
MartyMart
Thats the best use of a Microsoft product that 've EVER seen !!!!  :icon_mrgreen:
Plinky
Does it work all the time, unlike most MS products??? :D
Barcode80
Quote from: Plinky on November 22, 2007, 12:25:34 PM
well, i occasionally have to restart it... and it doesn't support ALL dmm's  :)
mac
I use Geo matcher, but I test for different values of Rset, 1k to 22k in a P45/90.
Use a Mac mouse.  8)
mac
no such packages, but you can install "Quad Cortex", "Helix" or "Kemper" instead.
Barcode80
hmm, i wonder if i am doing something wrong. everyone else seems to get less than a volt of negative voltage when matching, i usually get around 3!
stm
Quote from: Barcode80 on November 23, 2007, 01:15:11 AM
Seems all is good.  Different JFETs have different typical valoes for VGSoff (or equivalently Vp).
Values less than one volt (negative) are typical of J201's, while values as high as -3V are typical of MPF102's and 2N5459's.
Correct, stm.
In fact, I believe the MPF102 can be as much as -8V and still be in spec. Some JFETs have Vgsoff as much as -15V and can only be used in 9v designs with great care.
Barcode80
okay cool. i had like 10 2n5452's and when i started testing they were all in the 3 range and were REALLY close to matched already. must have been all from the same batch.
