4.7K instead of 5K volume pot for mosfet boost?
Started by pott, December 07, 2007, 07:05:10 AM
pott
Maplin doesn't carry the right 5K lin pots, all they have is a 4.7K. Would that be ok? Or can I use a 10K and make it 5K somehow? Thanks for the help, I have other choices but Maplin for now..
anchovie
Morocotopo
Also, since pots tolerance is (I think) 10 or 20%, if you buy a 4K7 you might end up with a 5K reading one, and viceversa!
Morocotopo
Morocotopo
10k will also work just fine, since just like a 5k pot it can be adjusted to resistances of less than 5k.
demonstar
I'm fairly sure I got a 4k7 pot from maplin instead of the 5k and I had no problems. Theres no reason at all why you should get any problems with that substitution.  :)
"If A is success in life, then A equals x plus y plus z. Work is x; y is play; and z is keeping your mouth shut"  Words of Albert Einstein
boogietube
Pedals Built- Morley ABC Box, Fultone A/B Box, DIY Stompboxes True Bypass box, GGG Drop in Wah, AMZ Mosfet Boost, ROG Flipster, ROG Tonemender, Tonepad Big Muff Pi.
On the bench:  Rebote 2.5,  Dr Boogie, TS808
