little gem on/off switch
Started by superfish, December 10, 2007, 09:07:27 PM
superfish
I know this isnt pedal related, but does anyone know how to put an on/off dpdt switch on the little gem amp?
ConanB
I assume that if you follow the ROG example you could just use a SPDT switch to break the ground between the battery and input jack.
ambulancevoice
superfish
ambulancevoice
simple
just get an spst switch (dpdt or spdt isnt really needed)
wire the 9V+ to one of the lugs on the switch, and and from the other lug, wire that too the circuit board power input
