Trimpot wah output buffer value?
Started by jpm83, January 02, 2008, 08:15:18 AM
jpm83
Can I use 200k trimpot in Fuzz Centrals output buffer? here's the link to the schemo. http://fuzzcentral.ssguitar.com/axiswah.php
Janne
  To adjust output volume yes. If you want 100k across the pot, you can add a ~200k parallel.
  200k should be just fine though.
jpm83
ampedup
i've been running mine full open so it probably won't matter what trim you use, i could replace mine with a 10 ohm resistor.
#4
  There are other ways to reduce/increase wah volume, volume control on the end is simple enough really though.
  Buffer won't increase gain, might sound louder when an impedance mismatch or driving a long cable isn't causing losses.
jpm83
I'm doing this just for insurance that my wah will work before fuzz pedals.
Janne
