Japan made CE-2 has slight distortion any one know what could be causing this???
Started by signalpaths, January 12, 2008, 10:41:34 PM
signalpaths
I have one of the older Boss CE-2's from japan and it is getting some dist in the signal.  Could this be from the electrolytic s.  I've heard that they can go bad over 10 years.  If any one can shed some light on what could be causing this I would very much appreciate it.
Thanks all
Eric
miqbal
M. IqbaL
Jakarta
George Giblet
It could be that the biasing has gone off.  There is a pot to adjust it inside but I strongly recommend leaving it alone until you have written off all possibilities - unless you know how to set it up properly.  If you have a multimeter you can measure the bias voltage to the delay chip.
ayayay!
Check that OpAmp chip!  My friend's CE-2 started doing the same thing and we swapped with an identical chip.  Problem solved.
The people who work for a living are now outnumbered by those who vote for a living.
