Weird problem with T Escobedo circuit
Started by nordine, January 14, 2008, 07:46:23 PM
nordine
Hi guys,
this one is driving me mad, hope someone can think of something...
its the Q&D VCF:
from Tim's website
( http://www.geocities.com/tpe123/folkurban/fuzz/snippets.html )
the problem i'm having is the following:
circuit works perfectly on everything, until... suddenly stops working ...this may sound like lots of causes, but i've: double checked soldering work, checked mechanical causes -found nothing- checked IC, covered everything i could think off
the weird part comes when, to "fix" it, i just have to touch the IN with my fingertip, or the Vr point... then comes alive ... i don't have to press it, i just barely contact any of both parts and the circuit starts running
any guesses?
John Lyons
Something to do with the biasing and or loosing bias I guess.
Maybe the Vref connection is off somehow...?
Try dedicated biasing between ground and +9v with a couple 1Megs.
John
Basic Audio Pedals
www.basicaudio.net/
foxfire
not to side track this but, what does CV connect to?
nordine
thanks for the replies,
John, i suspected too some kind of biasing trouble... resoldered everything, and the trouble seems to have vanished.. ..the whole circuit, is a mish-mash of that Filter circuit plus a sample rate reducer, plus an LFO, so things were TIGHT inside there
Mark, i used a tl072, why?
foxfire, CV is the IN for Voltage sources, such as LFO's, Envelope Generated Voltages, or Expression pedals
Quote from: nordine on January 16, 2008, 08:09:16 PM
So that people who built it successfully and used that opamp could say so, or so that people who built it successfully with a different opamp but not with an TL072 could say so.
foxfire
for what it's worth i breadboarded one tonight with a 741 and it seems to work fine. thanks Nordine for the reply. thats what i was assuming it was for but, wanted to double check for good measure.
