How to add a LED that's always on...
Started by Renegadrian, February 04, 2008, 12:11:05 PM
Renegadrian
Let's say in the classic 3PDT-battery-adapter configuration, like the GGG layouts...
Like THIS
I'd like to add on a circuit (that's going to be always powered via an adapter) a LED that's always lit when the input jack is plugged...How should I wire it?!
Also,  what should be the its resistor value to make it last the longest time?!
searoad
u dont need the battery snap right?
take off the black wire from led(-) and connect it to the ring of input jack
and u can use a DPDT instead of 3PDT
Renegadrian
For what I understood, the ON/OFF LED will be no more that way, am I right?!
My goal is to have the classic configuration with the 3DPT and the ON/OFF LED, and a LED more that's always lit when input jack is plugged...
hendrix2489
i think it might look like this, http://www.flashpaint.com/sketchit.php?id=3689
whoops 2 people posted while i was making that masterpiece, sorry
Renegadrian
theundeadelvis
Couldn't you just wire the LED to the DC jack with a resistor between the positive lead and the lack?
If it ain't broke...   ...it will be soon.
searoad
#6
sorry i misunderstood...
so just add another led
ring of input jack---- (-) another led (+) --- (+) indicator led --- 4k7 resistor --- +9v
or
ring of input jack---- (-) another led (+) --- another resistor --- +9v
Renegadrian
All right  thank you for your advices!  ;)
arma61
Ciao
I think this is what you are looking for, as soon as you connect the input jack the new led gets "ground", and it's already connected to the positive.
Ciao
Armando
"it's a matter of objectives. If you don't know where you want to go, any direction is about as good as any other." R.G. Keen
Renegadrian
