switching between two inputs
Started by nag hammadi, February 13, 2008, 10:24:05 PM
nag hammadi
i would like to be able to switch between two inputs in my box from a footswitch.
one input would be a 1/4" and the other would be the output of a signal generator type deal.  :)
what is the best way to wire this?
in the face of you all i stand defiant - subhumans
  Simple SpDt
  pole in the middle goes to output
  the switch decides which input wire gets connected.
  I'd use a jack for the input, [and one for the SG input], but as long as the inputs and outputs have a common ground, the method of connections doesn't matter.
