Which enclosure for FSH-1 (Tonepad)?
Started by EunosFD, January 02, 2008, 10:06:18 PM
EunosFD
I hope this question isn't too dopey.  Ok, so I'm wanting to take the FSH-1 project on (the Tonepad version) and I'm not quite sure which enclosure would be ideal for it.  The circuit & peripherals seem to take up quite a bit of room so I'm just wondering which size enclosure have those of you who built it (or similar circuit) did you use?  I don't want to buy one which is too small only to have to send it back.  I'll probably buy it from Pedal Parts Plus since they sell 'em pre-painted (I at least want some part of the project to look nice  :icon_mrgreen:).  Would a 1590NS be large enough or would a 1790NS be better?
TIA
WormBoy
Just finished one (quite interesting sounds!), and put it in a "type C" enclosure (119x93x56.5 mm). It fits in there quite comfortably (I built it with all the mods, and two footswitches). Btw, if you hear the LFO ticking in the filter setting and/or in bypass, I have a quick and simple fix that worked well for me ...
