Capacitor questions
Started by theandyman123, February 06, 2008, 11:16:42 AM
theandyman123
Hey Guys,
First, I'm a totally newbie
Second, I have some questions about capacitors.
I'm going to try my hand at the Radio Shack Noisy Cricket.
Here is the build sheet
http://www.beavisaudio.com/Projects/NoisyCricket/MarkII/NoisyCricketMarkII_RadioShack_Rev2.pdf
When I went to Radio Shack, they didn't have film caps they only had ceramic.  Will this work?
Also, the rating on the build is in nf, all the caps there were rated in uf.  Is there a way to convert them, or does someone have a good resource for me to learn on the different ratings?
Thanks in advance
theandyman123
Andy
1. Read the FAQ.
2. In particular about capacitors; all caps are separated into (a) polarized and (b) non polarized. Polarized caps MUST be used in a way that the instantaneous voltage never gets reversed from the polarity marking. Non-polarized caps can be used with DC voltage either way, or pure AC. Polarized caps are made because you can get much higher capacitance in a small package with this technology. Otherwise, you would always use non polarized caps.
3. You will see a lot of magic mojo talk about the differences in sound of capacitors. As a beginner, ignore it. Use what caps you can get, and if you later need to change them out for perfect sounding lah-di-dah caps, do that. Your big challenge right now is getting anything to work at all. Which leads to - use the ceramics or films as you can get them. They will work.
theandyman123
thanks a lot R.G.
theandyman123
theandyman123
And just to double check:
47nf would be the same as .047uf
and
100nf would be the same as .1uf
laterz
theandyman123
Timebutt
Completed Projects: Gus Smalley Booster, Modded Russian Big Muff, Orange Squeezer, BYOC Vibrato, Phase 90
theandyman123
 ;D sweet, Radio Shack here I come.
skiraly017
Quote from: theandyman123 on February 06, 2008, 11:39:09 AM
and
laterz
theandyman123
If you ever have any doubt...Capacitor uF - nF - pF Conversion Chart.
12milluz
http://www.beavisaudio.com/techpages/Caps/
For general cap information, look at that. I learned a lot from it! :)
Quote from: Processaurus
You need a glade plug-in, in on a footswitch.  Kick on the big muff, then hit the air freshener pedal.
Visit my site: http://www.freewebs.com/12milluzmusic
theandyman123
Once again,
Thanks for all the help.
It is amazing how quick the responses come, and how generous you guys are with info.
laterz
theandyman123
Andy
DryRoasted
Just for reference Andy, when you get your caps, they should be marked like this:
47nf    =  473
100nf  =  104
...had me confused when I started out
Sticking a tube into a tube screamer to get good sound is about like rubbing yourself all over the weight stacks at the gym to get stronger - R.G.
