Newb Question
Started by DBDbadreligion, February 11, 2008, 08:46:25 PM
DBDbadreligion
I have searched and can't find it.
I have seen it on here before, but I forget how to do it.
I have a 100k pot and I want to make it 250k or even 500k, what do I do to raise the 100k pots value?
Thanks alot,
Nick
Nick Landt
DBDbadreligion@gmail.com
12milluz
I'm pretty sure you could add a resistor(s) to the lug which gets the signal in to increase it to the value you need. Don't quote me on that, though. ;)
Quote from: Processaurus
You need a glade plug-in, in on a footswitch.  Kick on the big muff, then hit the air freshener pedal.
Visit my site: http://www.freewebs.com/12milluzmusic
DBDbadreligion
ok, well thanks alot.
I will wait to see if anyone else has a reply to confirm this.
Nick Landt
  You dont.
  Pot is a variable resistor, actually two of them, one on each side of the wafer.
  If the wafer is 100k you get about 100k of variable resistance from it, no more, the wafer will be about 100k.
  You could add to it...bump it up' with a stop resistor means
  minimum resistance = stop resistor value
  Max R = stop resistor + pot value.
  But I rarely find useful applications for 'bumping' [FF gainpot being 1 exception], especially large pot values..
   Most of the time I'll put 100k where schematic says 250k then get a 250k or leave it at 100k.
