LM386N-1 can be used in ROG's Big Daddy?
Started by gigimarga, February 22, 2008, 11:00:51 AM
gigimarga
Hello,
I've just finished to build a ROG's Big Daddy (using this layout: http://www.runoffgroove.com/grace-sm.pdf), but no sound!!!
This seems to me very strange because it's a very simple effect...it is possible to not work because of LM386N-1...it isn't suitable for Big Daddy?
Searching on this forum I have read in a post that LM386N-1 accept at most 6V...it is possible to burn it from start powering it at 9V?
Thx a lot!
GravityRobert
Unless you chip is broken (or one of the pins not connected?) it should work fine. Do a debug on the pedal, should work fine, the lm386 can handle up to 12v so 9 wouldnt be a problem.
Quote from: gigimarga on February 22, 2008, 11:00:51 AM
Thx a lot!
suprleed
I've looked at numerous 386 datasheets online is preparation for building my ruby amp.  The LM386N-1 should work fine under 9V.  I believe its max operating voltage is 12V per the datasheet.  So if you were operating up in that max range I would say you may have fried it, but I would start looking elsewhere for the problem.
I suppose its possible that you could get a bad/dead chip from the manufacturer, but I would think that is pretty rare  ???
Sounds like this may be a good case for an audio probe.  I don't have much experience with those, but I'm sure others here could help you with that.
Good Luck
"That's the way I play" ~EC
gigimarga
thx for answers...i will try to debug it tomorrow...but i think that i bought the chip bad :D
