need help relp reassembling my deluxe electric mistress!
Started by sjaltenb, February 21, 2008, 11:27:04 AM
sjaltenb
hey yall, i took apart my deluxe electric mistress to put into my Cornish board but decided that I wanted the non-deluxe version instead.
So me, being an idiot, didnt take pics of the board or anything when i took it apart. I have most of it back together but have a question on the wiring..
I have
E4- White connects to input jack
E5- I BELIEVE goes to my output jack ground
E6- I BELIEVE goes to the left lug of the top side of the switch (side with TWO lugs)
E7- Yellow connects to lug on the bottom side of footswitch (side with only one lug)
I had also replaced the DPDT slide switch with a toggle. If i leave this wired as is, and i just corresponded the lugs from the slide to the one on the toggle...this should work, right?
Thanks!!!!!!!!!
MikeH
Quote from: sjaltenb on February 21, 2008, 11:27:04 AM
Probably, but I'd check the connections on the original switch with the continuity setting on your dmm first
