diode in4007
Started by Zedmin_fx, February 23, 2008, 11:57:11 AM
Zedmin_fx
Hi I have a 15 of these that I ripped out of a pcb from a old furnace. I was just wondering if they are worth keeping or not. If they are worth keeping,what would I most likely need them for. Thanks ;)
JasonG
I would recommend looking up the spec sheets on them. If they take a lot of current to forward bias ,you would not want them as clipping diodes. You could always use them as reverse polarity protection.
I would recommend putting most of the parts you " rescue" in one spot. Unless it is a known " mojo '" part like ac 128's. I pick up so much stuff from scrap pc boards that there is not much of a point in making sure you know where everything is at.
Class A booster , Dod 250 , Jfet booster, Optical Tremolo, Little Gem 2,  mosfet boost, Super fuzz , ESP stand alone spring reverb red Llama omni-drive , splitter blender ,
NEVER use gorilla glue for guitar repairs! It's Titebond , Elmers, or Superglue
Auke Haarsma
1n4007 is the same as 1n4001 (or any 1n400x). It can handle higher voltages, up to 1000v.
It can be used as a clipper (in fact the 1n4001, is used as clipper in e.g. the MI Audio Blues Pro)
Datasheet herer: http://www.fairchildsemi.com/ds/1N/1N4007.pdf
ambulancevoice
also, the 1n4007 is popular in power supplys as recifiers
i think they can be used for polarity protection too, but im not sure if its only 1n4001 or any 1n400x
Zedmin_fx
Hey thanks for all your info I have a hole crap load of stuff that I am getting from the pbc. ;D
Gus
