Primer question.
Started by BaLaClavaAa, March 15, 2008, 02:05:35 PM
BaLaClavaAa
So I've build a pedal, and I've bought a case, and it's time to paint =]. So my question is, after i sand ( low grit-800grit?) it, so I need to use a self etch primer, or can I just go straight onto my enclosure with the coloured primer? I am using an enclosure from small bear.
Thanks for your help.
boogietube
Personally, the only good results I have had were with self etch primer.
Check the WIKI on the top of the page for threads on finishing. Very useful.
Pedals Built- Morley ABC Box, Fultone A/B Box, DIY Stompboxes True Bypass box, GGG Drop in Wah, AMZ Mosfet Boost, ROG Flipster, ROG Tonemender, Tonepad Big Muff Pi.
On the bench:  Rebote 2.5,  Dr Boogie, TS808
plankspank
Self etching primer actually etches into the metal, so the actual color coats adhere to it better, so there is less of a chance of it chipping or flaking off later down the road.  Regular primer will work o.k., but won't have this advantage...
I also like to use steel wool as the final prep, and then wiping the enclosure with isopropyl alcohol before priming....
gutsofgold
I have some "sandable" self etching primer. It's that lime green dupli color stuff.
Do you guys actually sand it after a few coats before adding the color coat? Or should I just let it etch and then spray right on to it.
Dave Simpson
It depends on the texture you want the finish to have.. I find 400 grit on the primer before the color coats makes the finish pretty smooth through out the color coating.
mike_a
excuse my noobness, but why not use a color suited especially for aluminum painting?
I was at the hardware store and the seller showed me an acrillic-based spray paint that is meant to be sprayed straight on aluminum.
wouldn't that work?
Aluminum being the odd stuff that it is, the answer to EVERY question about aluminum that ends in "wouldn't that work?" is
"Maybe. Have to try it and see."
mike_a
Good thing I bought it then  :icon_wink:.
I'll have a try (hopefully this weekend) and report back.
BaLaClavaAa
Ok thanks, so the general gist is that it isn't absolutely needed, but recommended =]
bipedal
Yeah, primer is recommended.  I'm on my 6th or 7th build now, and I have not used self-etching primer thus far -- just sanding, followed by several light layers of Krylon general purpose spray paint, followed by clear coating; no baking or anything.
That has worked okay, but I have noticed that the finish on one of my pedals -- one that I throw in a backpack with cables and other stuff that I haul to band practice weekly -- has already started to chip in spots.  Looks cool in a sort of broken in way, I guess...
I plan to start using self-etching primer on new builds in the hopes of getting something more rugged and long-lasting.
- Jay
"I have gotten a lot of results. I know several thousand things that won't work." -T. Edison
The Happy Household; The Young Flyers; Derailleur
Lachlan C.
In my opinion (Not expert or definitive by any stretch) I would probably go with a dedicated self etching primer first. As others have pointed out, you can use self priming colour coats no probs but I think the finish will be better with a coat or two of self etching primer first. I have achieved very even results with lightly sanding the bare enclosure with 180, 260, 360, 400, 600 and then applying a self etch primer. The enclosure being primed with a dedicated primer first means that you will have to do less colour coating to get an even finish.
The most important thing to keep in mind for achieving a good, scratch resistant finish with paints is to allow ample time between coats to both dry and cure (read strengthen). Personally I've had a good run recently due to Mother Nature being on side - high 20's - 30's deg celius and low-mid humidity. I guess Australian weather isn't too bad...
Best of luck with enclosure(s) - post some pics post painting
- Lach
