New Soldering Iron
Started by BillyB, July 25, 2007, 08:26:36 AM
BillyB
Well im getting tired of my 2 Radioshack irons.  One broke on me, but they both just burn up tips.
Any recommendations for soldering stations/irons?  Keep the price fairly low $50-60.  I saw someone mention a nice one a few weeks ago but I forget what it was.
Thanks for the help,
Billy
ulysses
i use goot irons and i love them.
cheers
ulysses
dano12
I've been through all the crappy Rat Shack irons. On the advice of several forumites, I got this Xytronics model:
http://www.circuitspecialists.com/prod.itml/icOid/7501
39 bucks, and it is the best iron I've used. Highly recommended.
BillyB
Dano- Cheers!  That was the one I mentioned that I forgot what it was called.  Thats what im going for.  Thanks!
By the way, whats that wierd gold stuff on the left?  Tip cleaner?
Thanks,
Billy
dano12
Quote from: BillyB on July 25, 2007, 11:36:17 AM
Thanks,
Billy
Yes, a tip cleaner. Much better than the wet sponge approach. Just jam the tip into the gold wire stuff and twist it around a bit.
Others use Brillo type/metal scouring pads (ones without soap) with good results.
theundeadelvis
If it ain't broke...   ...it will be soon.
Solidhex
Yo
  Was looking for some info on good soldering irons and dragged this thread from the past. I had the red Weller one but it just crapped out on me. I was looking at the one Dano had mentioned in this thread and was wondering how readily available the tips were for them. The thing I liked about the weller was being able to replace the tip at my local electronics store.
--Brad
Sir_Ian
I work at Harbor Freight Tools, and today I noticed a 50 or so dollar soldering iron on sale for like 30 dollars. I don't know how good it is. It was variable temperature (you could set it between like 200 and 900 degrees farenheight). I wouldn't drive an hour just to look at it. It was a great deal, but a deal none the less. But if you have one in the close vicinity, I'd consider taking a look.
Time flies like an arrow, fruit flies like a banana.
  Yupp...red weller one did that on me.
  Runaway heat is the theory, I left it set pretty hot, i think it baked the element [17 dollar/ warranty item].
  With this tip I'm trying to keep between 12 and 1 oclock on the dial unless the tip is having the heat sucked out of it on a fat lug or something, I set it at 4 or 5 oclock for that, then right back down to about 'noon'.
Solidhex
I wouldn't mind getting one that turns off automatically after an extended period of time. Hate that "did I turn off the (oven, coffee maker, solder iron)?" feeling.
--Brad
Incubus
Heres a pic of  NASA engineer soldering a connector for the fuel sensor which goes into the external fuel tank of the space shuttle. (from 2 missions ago).
He likes his weller.
http://img190.imagevenue.com/img.php?image=89108_170419main__DSC0049_1024_122_158lo.jpg
For what it's worth, I use a Hakko.
scaesic
Quote from: dano12 on July 25, 2007, 08:48:13 AM
+1
Works 1000 times better than those cheapy throw away irons you get, where the tip just corodes making it impossible to use.
Best price/performance i could find.
The only diff to this model is in the place of a spounge i got a small wire tip cleaner, like the cleaner next to the station. So even better.
eurekaiv
#12
Is that Xytronix considered better then the $40 model sold under the "CircuitSpecialists.com" name (that's rumored to be identical in every respect to a FAR more expensive Hakko) here?  I have this one and it's really good, the wand is especially nice (and easily replaceable on the fly) and there seems a larger selection of tips sizes and shapes available, but I've never noticed the Xytronix stuff on their site since they weren't included under the "soldering stations" category.
mutagenic
I have that one too, I absolutely love it.  I've had it for about a year with no problems.
Solidhex
All right.. I'm sold. Got one on the way.
--Brad
