IC orientation
Started by aettin, December 25, 2011, 06:05:53 PM
aettin
Hi guys-
Feeling a bit stupid here. I have an IC (4093), and am not sure which way to orient it. The actual chip has a semi-circle divot on the one side, and a full circle indent on the other side. Which side do I orient with the square block on the layout? I usually just match the side with some sort of indentation with the square, but on this IC I have 2 types of markings? Please help.
Thank you very much for your time.
Ronan
The big semi-circle taken out of one end has pin 1 beside it, disregard the other small circle. Assuming it looks like
this.
Divot? I had to look that up - obviously I don't play golf!
aettin
That's awesome. Thank you so much. Hahaha.. I'm from South Africa.. perhaps our vocab is bit odd.
Earthscum
Just for the sake of throwing info out there... the full circle you find on some chips is from the plastic molding process. It's caused by a pin that pushes the chip out of the mold die. If the pin isn't perfectly flush with the surface, it leaves either a divot or a nub.
I'm from Wyoming... divot is in our normal vocabulary in the Rocky Mountain region. But we also call creeks "cricks" (lazy between an e and an i sound). *shrug*
