Dr. Boogey problem
Started by kawayanstrat, May 10, 2008, 02:52:56 PM
kawayanstrat
I recently finished my 2nd DRB,and it worked right away after firing it up. Here's the problem. After testing the DRB,it was really fine. I left it on my work table for a few days cuz i have to work on the enclosure. After 3-4 days i fired it up again but this time the gain of theDRB,went from 100% to 10%. How the hell did that happen?  What do you guys think caused the problem? I've checked for cold solder joints but everything seems fine. I also checked the j201s and even swapped it with new ones,but it still has very low gain. Please shed some light if this already happened to you.thanks in advance!!!
DimebuGG
eto ba yung sinasabi mong 50% less gain bro??...kanino kayang order na yan?.. :icon_biggrin:
kawayanstrat
#2
Quote from: DimebuGG on May 11, 2008, 09:02:09 AM
Sino to? Naayus na to kanina. Sira yung pots na kinabit ko. 8)
Edit:
I already fixed this. Well,it turned out that i have a broken potentiometer. It's running like hell already! :icon_twisted:
