Question about R.G.'s Polarity Reverser
Started by ianmgull, May 13, 2008, 09:52:31 PM
ianmgull
Hello,
Sorry if this has been covered before but I can't find an answer.
Does anyone know what the resistor value's are supposed to be for this:
http://geofex.com/Article_Folders/polarity_reverser/polarity_reverser.htm
I'm building a parallel distortion box:
http://www.diystompboxes.com/smfforum/index.php?topic=67435.0
And I plan on putting the buffer on the same board as the Polarity Reverser.
Ian
Pushtone
I think you PM'd me about this. Sorry I didn't get a chance to answer
I want to know the same thing.
I have the circuit on the bread board right now with a buffer in front of it.
I'm getting a slight drop in level when the switch is closed.
I've tried a lot of values but I can not get unity in both states of the switch.
I lost some interest in getting my parallel effects mixer project done.
This is a good time for a thread. May get me back into it.
Need sleep now. tomorrow I will go over the values I'm using on the bread board.
kvb
#2
The ROG spliter-blend has an extra buffer and uses 220K for the other resistors.
R.G. told someone - in a post, who knows where - that 10K can be used for the other resistors.
I breadboarded the circuit and used both values - without an extra buffer - and things seemed to work just fine.
I double check for the polarity change by mixing two signals together and listening for a cancelation.
kvb
Also, if you are just trying to maintain polarity between different circuits - that are permanently configured - you do not need the polarity reversal circuit. Any single transistor stage can be either an inverter or a non inverting buffer. You just need to keep track of how many inversions there are in each circuit. An inverter at the end of a certain circuit - depending on the values used - might not change its sound much and may give you other options like additional tone shaping without volume loss.
dschwartz
totally agree..you donĀ“t need the polarity reverser..just an inverting gain or buffer stage..
Tubes are overrated!!
http://www.simplifieramp.com
ianmgull
Thanks for the info guys.
I know personally I am blending five signals: 2 Tube Screamers, a Big Muff, an Uglyface, and the clean signal. You don't think I'd need to worry about phase cancellation?
thanks again.
ian
dschwartz
check in each one of those circuits if the output is out of phase.....if one of them is inverted, then use a phase inverter (I.E. fet or transistor gain stage with gain= 1)
Pushtone
I think Daniel means that it is not unnecessary when the circuits you are parallel mixing are permanently configured.
Just build them with a non-inversion output.
You absolutely do need the polarity reverse if the idea is like JD Sleeps PARALIZER where any circuit can be connected to a loop.
Dave
ianmgull
dschwartz: Thanks, I'm still in the middle of a 450 page electronics theory book but I've not gotten far enough yet to be able to tell if the circuit is out of phase yet.
Pushtone: Conceptually my box will be like JD's Parallelizer, except it will all be in one box, with the 5 channels I listed above. I'm sorry but I think I misunderstood you, it is "not unnecessary". So you would recommend I do put the inversion circuit in there?
Thanks for the help.
Ian
dschwartz
ian:
is not that hard..look:
- if the output of a transistor or fet stage comes from the drain (or the collector), the stage is inverting (typically gain stages)
- if the signal in an opamp goes into the - input, the stage is inverting.. (some gain stages)
- if the output of a transistor or fet stage comes from the source (or the emmiter), the stage is non-inverting (typically buffers)
- if the signal in an opamp goes into the + input, the stage is non-inverting.. (some gain stages, and buffers)
now, follow the signal through each stage of the pedals, checking the polarity of each output..
do it like this:
for each stage asign number 1 if non inverting and -1 if inverting, for example , a signal chain:
inverting--> non-inverting-->inverting----> inverting
is:
-1 ---> 1 ----> -1 ---> -1
then multiply the numbers:
= -1*1*-1*-1= -1...then the entire chain is inverting
as a rule, if the chain has an odd number of inverting stages, the output will be inverted..
then..you have to invert the signal again on those pedals having inverted outputs..
ianmgull
Wow, thanks for the help Daniel. That's exactly what I needed to know. So it looks like I wont need to worry about inverting the signal in my box. Thanks!!!!!!!!!
ian
