Dumb Neutrik Jack question
Started by msurdin, May 08, 2008, 06:20:00 PM
msurdin
I just got these in the mail and I was wondering which solder point is ring,tip, sleve...
(silver end to the left is the input area if it is not obvious)
Matt
drewl
in your pic right to left is Tip-Ring-Sleeve.
think of how the plug goes in, the very end is tip, middle is ring biggest part is sleeve.
theblueark
The easiest way to figure out any jack is to plug in a cable and measure check for continuity with a multimeter. Or mostly also you can physically observe which part is making the connection with the plug.
jayp5150
I use those jacks a lot, and when wiring, be sure you don't wire to the switched lugs...
Takes you like an hour to figure out why you have no signal.  >:(
Then you just feel dumb all day lol.
raycroft
Master Learner
