some questions about boxing together: thor, dr.boogey and tonemender eq
Started by beatnik, May 17, 2008, 08:36:01 AM
beatnik
I am planning to box these three effects together. The tonemender will be the common tonestack for thor and db.
The first question is about removing the dr.boogey original tonestack (wich i don't like too much). Is there a schematic available? I founded one by martymart but it is marked as unverified.
I don't need three separate volume controls, so have to choose between:
A) eliminating volume controls from both the thor and the db, and using the tonemender clean boost as a common volume control.
B) eliminating clean boost from tonemender and use two separate volume controls for thor and db
I think i would prefer the first option, but don't know how to remove volume controls from the thor and the dr.boogey. (i'm so noob.... :P)
rock_god_dan
If you're looking at gaussmarkov's new schem of the Dr Boogey, the components after q5 and before r15 comprise the tonestack. There's a presence knob too, so if you want to remove that, remove r15, c13 and the pot. I can't help you with the volume pot though, I think the tonemender doesn't have one. I think to use the tonemender as a clean boost, you can't use it as a tone shaper at the same time. Best of luck!
Dan
