Several post-etch questions
Started by deadspeaker, June 20, 2008, 10:47:42 PM
deadspeaker
I did my first etch today! It's actually for an amp, but I thought I'd share here anyway. I used whatever gloss paper the girl at officemax put in the printer. Ironed it on and it kind of stuck for the most part. Touched it up with a sharpie and then dunked it in some muriatic acid several short times because I didn't want to over etch it. Anyways I over etched it.
1) Will I be able to fill the broken up looking pads with solder?
2) Some lines are touching others. What is the best way to separate them?
3) The smallest bit I have seen at lowes/homedepot is the 1/16. Is there some kind of bit or dremel attachment that I can pick up at lowes or the other to drill tiny holes.
Thanks for your guys help.
JOHNO
I dont think solder will bridge the gaps ,it depends on how big the gaps are. you could use a lead of a resistor soldered across the gaps though. As for the traces touching you could use a small file or carefully cut them with a small knife. As for the dremel bit i cant help you there. good luck . JOHNO
deadspeaker
I just took a multimeter to it, and things arn't that bad. I also discovered that I have a little dremel thing that sands off the unwanted connections. I guess I could sand of the really then traces completely and use resistor leads to connect them. Thanks for the idea.
Filament
Quote from: deadspeaker on June 20, 2008, 10:47:42 PM
The best way I have found to drill the holes in the pads is with the tiny drill bits that drill bit city sells.  I think you can get a ten pack of resharps for about 12 bucks and they work wonderfully.  In fact, I just bought another ten because I had gotten down to four when my uncle accidentally broke one because he didn't realize how small it was.  Here's a link to the size I use.  You'll need a slightly larger size for some of the protection diodes that have the really big leads but those are few and far between. Hope that helps.
http://drillcity.stores.yahoo.net/680310resharp1.html
Oh, and get yourself a drill press....please.
This is not my large automobile
raycroft
Master Learner
deadspeaker
Wow 2 dollar or so set looks great. I might get a couple sets. I found my self at lowes again today(I build random stuff. I think I'm addicted) and I discovered a tiny bit set in the dremel area. It was about 8 dollars and it ranged from a 1/32 to a 1/8. Pretty happy to find that so I could drill today. I had to use masking tape to get the bit to stay in the dremel, but I didn't break it! Now I know I'll break it eventually, so I'll see about getting those cheep ones. Thanks for the help
Filament
I'm not usually so forward but I'm telling you, in the long run, the 11 or 12 bucks you spend at drill bit city will be money well spent.
birt
those "expensive" drill bits don't break as easy when using them. as long as you drill straight down and be carefull they last a VERY long time
http://www.last.fm/user/birt/
