Green Ringer
Started by eggman6, June 09, 2008, 06:41:17 PM
eggman6
Built a Green Ringer on prototype board, it works, but it doesn't. It seems to act as a booster and no octave, i finished it not so long ago and so will check it properly tomorrow since its quite late. I initially forgot the 100uf electrolytic, but putting that in didn't change much. Probably a silly mistake i've made somewhere, but it does seem a bit confusing.
eggman6
Okay just came to me this second, i bet i've put the diodes in wrong. I'm not generally this stupid.
Yea went in wrong way round, could this damage the transistors, or the diodes?
  Shouldn't have damaged anything...
  Check the transistor orientation, notice which way the emitters are pointing, it uses PNP and NPN transistors..
eggman6
Yea i made sure i got the tranistors right, downlaoded the spec sheets, but me being me completly forgot about the diodes.
  No matter, stick 'em in there the right way round...
eggman6
Hmm no luck only works when one diodes are facing opposit directions (the initial mistake i made), just going to rip this apart and start again. Maybe i should just stick with amplifiers.
eggman6
#6
ok, is it possible that any wiring error could damage the transistors or diodes? The only way i can get any signal is if each diode is pointing in a different direction in relation to the other.
Only other factors i can think of is that the battery is low, reading at 8.40v dissconnected. I cant imagine it being a ground problem since everything is grounded apropiately, i haven't grouped or organised the grounds in any perticular way but then i didn't think something such as this would be as touchy on ground placement as amplifiers are. I've got plenty of 2n5089s, but only one spare 2n3906 and no diodes.
eggman6
foxfire
eggman6
Went from the 560k, to the 160k without going to pin 2 of Q1. I'm the worst for these mistakes, i built a soldano style preamp and spent a day wondering (losing my mind) why it wouldn't work, when i had just forgot to ground the input.
I noticed the tonepad green ringer has a 2m2 input resistor instead of the 1m5 on GGG, what difference does this have?
MikeH
The difference is 1, maybe 2 hills of beans.  It's just a pulldown to keep the switch from popping.  Anything above 1M will work.
