Etch resist for aluminum?
Started by JKowalski, September 05, 2009, 11:19:45 PM
therecordingart
Quote from: deadastronaut on March 29, 2010, 07:47:04 AM
Quote from: mikemaddux on March 29, 2010, 07:39:47 AM
Quote from: deadastronaut on March 29, 2010, 05:40:19 AM
but if you cover the sticky residue with mayonaisse and leave for half hour it comes off  easily,...(starnge but true)...
I have to ask........how did you find that out?  Eating a sandwich while etching? lol
yeah sort of!....lol...no i saw it on a crappy house cleaning tips prog on tv!..works tho..i hate having to peel off sticky labels
that leave crap behind..ha ha..
Is it the concentration of vinegar in mayonaisse that does it?
differo
Slade, can you reveal the mystery with your paper: do you print on the glossy or dull side? is there paper covering toner in your tutorial? (multicolor etching)? It appears to me from your images that, when you peel off the paper, some thin layer of paper is left on the enclosure covering the toner? How long do you wait (after applying nail enamel and toner) until you dip it in fecl? and finally, do you warm your fecl or you just dip enclosure in some tray (perhaps placed on table..)?
Thanks for your great tutorial, that is the etc-bible! :) (together with markm's!)
My youtube channel:
http://www.youtube.com/user/BeToneful
Rebote2.5,MXR dist+,DrBoogie,BSIAB2,Ross Compressor&Phaser,MXR EnvFilt &Noise Gate,TS808,Condor CabSim,SansampGT2,Fraverb,Small Clone,TremLune,ValveCaster
therecordingart
Kinda off topic....anyone do an electrolysis etch yet? I've built an etching power supply that can switch between DC and AC so you can engrave the metal, and then blacken the engraving, but I haven't tried it on an enclosure yet. I've messed with eating copper clad to make sure it worked.
differo
Quote from: therecordingart on March 29, 2010, 10:48:49 AM
I did (and some others) worked quite good on metal sheet (steel?) quite deep etch too, but no go on aluminum (for me at least..). Still have my 'etch-tool' to experiment some more when I find time.
My youtube channel:
Skruffyhound
Again O.T., but has anyone tried the Eco etch of copper sulphate/table salt and water? My results have been sketchy so far but that's mainly because I'm trying to use it with a UV/photoresist system and I think it is getting too hot for the resist. It definitely eats aluminium and you can also increase the effect by passing a current through it if you think it's necessary. Renewable too and much less toxic than the alternatives.
Hides-His-Eyes
Quote from: Skruffyhound on March 29, 2010, 12:51:05 PM
very interesting. So I could hook up say a 9V battery between an electrode and the case, and etch away a design like that on the aluminium? What kind of timescale are we talking?
Hides-His-Eyes
http://www.nontoxicprint.com/etchzincsteelaluminum.htm
very interesting. copper sulphate isn't expensive, I just wouldn't like to go through the whole 'press n peel" nonsense for the etch resist. Maybe i could make simple designs using masking tape or similar? Cover the back and cut out with a stanley knife (it'd scratch but then it'd be etched where it was scratched and wouldn't be noticeable, maybe?)
therecordingart
Sorry to remain off topic, but copper sulfate? What about chelated copper sulfate? If that works you can buy the stuff at your local pet store or aquarium place...it's used in fish tanks.
StereoKills
#28
Quote from: Hides-His-Eyes on March 29, 2010, 01:26:38 PM
12v should do it with a large current rating. Method I've seen for brass was 12v, 17A in a solution of root kill. Should be possible in a solution of salt water as well.
"Sometimes it takes a thousand notes to make one sound"
Slade
Quote from: differo on March 29, 2010, 10:41:12 AM
You should read the tutorial again :icon_biggrin:
Always on the glossy side.
Yes, it's there. When I peel off the paper there is some sticked paper over the toner, that's an important key for the process...
Approximately 10 minutes, it depends on the time that the nail enamel needs to get dry.
No, I don't warm it, I do it exactly like in the tutorial pics.
Greetings ;)
StereoKills
Quote from: Slade on March 29, 2010, 04:35:39 PM
I used PNP Blue on the enclosure I etched and was a bit disappointing at how much FeCl got through the toner. The layer of paper must make quite a difference in how much it resists the acid.
differo
Greetings ;)
Thanks man, simple explanations worth a while! ;)
Will try again, somehow I want to believe that the key is in the paper/transfer.
My youtube channel:
Skruffyhound
Sorry again for offtopicness.
The copper sulphate/salt mix generates it's own kind of charge as I understand it, literally stripping off a molecule at a time, so it may not be necessary to send any current through it. Best results when mildly warm. Wear a dust mask when mixing the solution. Other products may work but who knows what else they contain in addition to Copper Sulphate. Masking tape is an effective resist, acrylic paint is another more flexible solution. I am working on silk screening acrylic on as a resist. The chemical reaction releases Hydrogen I believe, but it is not considered dangerous. Hide-His-Eyes's link above is one of the best sites I found.
