2 Rat 2's... Vero drawn, help wiring.
Started by BaLaClavaAa, June 18, 2008, 04:04:54 PM
BaLaClavaAa
So I followed Soulsonic's schematic (found here http://www.aronnelson.com/gallery/main.php/v/soulsonic-fx/ProCo+Rat2.gif.html), and I made up a vero for it. What I wanted to do is put 2 rat2s in 1 box so I made it so both would fit on 1 board.
Here is what I have so far:
Note, the red scrible on the board is saying to ignore those jumpers. The whole under pin 5 is saying to remove pin5 altogether NOT to put a whole in the board. Q2 and Q4, the jumper represents the middle leg. The cut is really there.
Also another cool thing is that since it is Soulsonics schematic, you could easily change some values and do his mod =]
Now it's not verified yet, but I need a little help finishing it off. First off I have no clue how I would wire the dpdt's togeather since they are both in rat bypass (I know how to for regular and 3pdt). Also I'm not really sure how to wire the battery snap and power jack so as to wire both pedals. Would I just add a wire connecting the 9+ lines and a wire connecting the ground lines? I'm also not really sure on the in&out jacks either.
Thanks =]
