moding wah into volume, how to remove clic?
Started by bent, August 21, 2008, 10:22:21 AM
bent
i mod my wah to wah/vol using a 3pdt switch, and i have to invert pin 1 and 3 of the pot on the switch to make it work , but it make's a click when changing... anyone know if i could put a resistor or a cap somewhere to prevent the click....
thank's
bent
Long live the music.....
bent
AzzR
The pulldown resistor is the 1M or so resistor on the input right?
This has previously worked for me to prevent pops.
-Azza
A Broken Clock Is Right Twice A Day
bent
Quote from: AzzR on August 21, 2008, 11:57:11 PM
-Azza
so i put a 1M resistor directly on the input to the ground? before the signal reach anything..  :icon_question:
bent
fuzzo
It's odd, everytime I do a bypass I haven't "pop" . Are you sure, your connexions on switch  are good ?
Otherwhise , you talk about modify your wha into a volume pedale but you want a wha+ volume or volume only ?
bent
Quote from: fuzzo on August 22, 2008, 03:36:08 PM
yeah, every connection are good, i never have a "pop" before, but normally i build effect, this time i convert a wah into wah+volume, so i use a 3pdt sw and choose between wah and volume....
bent
