Fuzzface Wiring Questions W/ Pics -
Started by Easywider, August 30, 2008, 04:35:39 AM
Easywider
Wanting To Start Wiring , But In Question ....... Using The Tonepad Wiring Diagram :
http://www.tonepad.com/getFileInfo.asp?id=76 , Lugs On Circuit Board & Directions :
Input
Ground
Fuzz 1
Fuzz 2
+9v
Fuzz 3
Volume 3
Volume Lug 2 :  To Effect Output , Lug One To Ground
..........Looked At The Tonepad Diagram , & Wondered Upon Lug Ones Ground From The Volume Pot......Does That Get Wired To The Sleeve Of The Output Jack ? ? , & Then Connect Both Jack Sleeves ?.......Just Making Sure I Get It Right From The Get Go , Attached Pics So Far , & Wanted To Thank Dragonfly For The Swirl Paint Tutorial & Awesome Loaded Circuit Board , Valoosj , For The Light Emitting Boarder Tutorial , To All That Have Helped Me.......& The Rest Of The Community Here , .....I Could Have Never Built Myself All The Goodies I Have ! !
Any Help , Or Better Way ,  Grately Appreciated  On Wiring This Up , .....Still Learning  ! !    :icon_twisted:
Thanks ,
Chris
andrew_k
Oh. My. Goodness.  :o    Sexy.
Your assumptions are correct RE: grounding and sleeves.
May I suggest you get an internal-mount DC socket? (thread an nut are on the inside, essentially the reverse of what you have now) as it will sit almost flush with the enclosure and look better. The existing mounting hole will be the correct diameter.
Easywider
Andrew , Thanks For The Heads Up On The Wiring , & An Internal Mount DC Socket Would Be Cool ! !
Best ,
Chris
asfastasdark
Wow what a BEAUTIFUL pedal! How did you paint that? Swirl? And what is the diamond-shaped thing under the switch, and did you use split-shaft pots? And yes, your assumptions are correct, by the way. I also think you should add a DC jack.
Easywider
Thanks Sander ! Learned The Painting From Dragonflys Swirl Painting Tutorial , Thanks Andy ! :icon_wink: Can Be Found Here : http://www.aronnelson.com/gallery/main.php/v/DRAGONFLY-LAYOUTS_0/swirls/HOWTO/ . The Diamond Shaped Thing Under The Switch Is What Fell Off Of My Nocona Leather Western Belt , Just Drilled A Hole In The Middle , & The Pots Are Solid Shaft 16mm Alpha's !
Chris
ambulancevoice
damn awsome
looks like you used almost every bit of mojo in the book!
blue led, swirl paint job, light emitting boarder, nos/vintage components, skull knobs
and no boring white switch washer! :D
asfastasdark
Quote from: ambulancevoice on August 30, 2008, 07:37:35 PM
damn awsome
Light emitting border, hadn't even noticed that yet, that must give a really awesome effect at a gig in the dark. How did you do that? Is it just the LED shining through the enclosure?
ambulancevoice
Quote from: asfastasdark on August 30, 2008, 08:44:31 PM
search is your friend
Light Emitting Border tutorial: http://www.diystompboxes.com/smfforum/index.php?topic=66840.0
asfastasdark
Zedmin_fx
Hey have you finished this up? would you care to let us see what the guts look like when your done ?
Easywider
#11
Quote from: Zedmin_fx on August 31, 2008, 11:04:07 PM
: Not The Best Wiring Job I've Done As Far As Neatness.......
But Finished Today , & Working Grrreat  , Thanks Again Andy ,.....For The Killer Loaded Board , ....Sounds Awesome  !  :icon_wink:
Best ,
Chris
