2N4248 PNP equivalent needed
Started by Dr Ron, September 05, 2008, 07:29:10 PM
Dr Ron
I'm not able to find anyone that stocks the 2N4248 PNP transistor (used in an Acoustic 370 bass amp)
and was wondering if there's a modern replacement widely available (i.e. from Mouser).
Thanks!!
theehman
Ron Neely II
fx schematics and repairs
It's not that fancy. Datasheets are your friend. It's PNP, 40V Bvceo, hfe of 50 minimum. 2N3906 should work unless it's a weird application.
sean k
Thats a universal 40V, 100mA, .2W transistor with a DC forward current gain of 50 whereas a 2N5089 has a forward current gain of 400, and hfe measuring about 550 0r so, so any low gain pnp should do. Looks to be really low gain, just over a 100 hfe. Quick check though and we use BC types over here and the BC560 is indicated as an equivalent  but they aren't at the local so I'd grab a bunch and use the one with the lowest hfe and work up.
2SA970 and 2SA1137 are also listed. Any low gain pnp I guess.
Monkey see, monkey do.
Http://artyone.bolgtown.co.nz/
Dr Ron
Thanks ... Talonix has most of the parts on my list!
