Red Llama mods
Started by Blacklake, March 28, 2010, 03:16:40 AM
Blacklake
Hi guys.
Does anyone have a mod, or an idea on how to squeeze some more gain/distortion out of a Red Llama circuit?
It sounds great as it is, but it would be cool to be able to push it some more when needed...  ;)
//G
mikemaddux
Completed Builds: A lot...
Blacklake
Ok, Thanks!
What resistor would that be, referring to the GGG shem?
http://www.generalguitargadgets.com/pdf/ggg_whrl_lo.pdf
fuzzo
maybe you can use more "gain stage" from the chips, I tried that but it appeared a lot of noise and oscillations (breadboard).
Otherwise, you can put a booster in front of the circuit , some pedals have that kind of configuration (calinbread SCO , ehx hot tube, appliance something ect.....)
fuzzo
#5
cool thanks !
I've some 4049BP and I wanna make a distortion circuit using it. All  cmos chips are the same?
slotbot
You can increase the gain by increasing the resistance in the first feedback loop. You could also lower the 100k at the first input. The gain of the first stage is pretty dependent on the ratio of the feedback resistor (the gain pot + 100k in series) to the input resistor (the 100k going into the first inverter from the input).
You can calculate it close to (100K + pot)/100k so when the pot is at the minimum the gain of the first stage is close to 1, and at max close too 11. If you make the input resistor 10k instead say you woudl get a range of ~10 to 100 (in the first stage).
I made one with a switch like the original craig anderton design, where flipping the switch puts a 10meg resistor in the feedback loop of the first stage, making the gain about 10  times more. Sounds pretty good.
WGTP
You need the 4049UBE or unbuffered chip for most projects around here.   :icon_cool:
Stomping Out Sparks & Flames
Hides-His-Eyes
If anyone the right side of the atlantic can sell me unbuffered for less than ~£1 each, shoot me a PM, or i'll have to ebay it.
Blacklake
Quote from: slotbot on March 28, 2010, 03:50:06 PM
Thanks! I´m going to give it a try right away! :)
//G
ItZaLLgOOd
I wanted to put a BM tonestack on the end of a jacked up Llama for a while but haven't had time.
Lifes to short for cheap beer
slotbot
Thanks! I´m going to give it a try right away! Smiley
//G
ya i have a really bad video with no sound here that you can see the difference on a scope at least between with and without the 10 meg added.
around 23 seconds you see it get alot more square, that is in "high gain" and then around 30 it goes back to normal gain. sorry no sound clip :(
http://mtlasm.blogspot.com/2009/10/red-llama-clone.html
WGTP
The BMP tonestack on the 22/7 from ROG is nicely done.   :icon_cool:
