quick question about voltages
Started by skibum1999, October 13, 2008, 01:18:18 PM
skibum1999
if you are reading wierd voltages on a circuit, does this automatically mean the problem is on the pcb or can it be an offboard issue too?
aron
It can be anything, but usually it's either a wrong value resistor, bad soldering, wrong orientation of transistor.
Boogdish
An easy way to see if it's offboard or onboard is to check the voltages coming out of your 9V jack or your battery.  If you're having trouble, check this first, it's a lot easier to change batteries than it is to resolder your components.
