Positive ground pedals and isolated power supplies
Started by Bucksears, October 16, 2008, 09:03:42 AM
Bucksears
I'm currently using a BBE SupaCharger (love it, want to buy another) that has isolated 9V outputs. Can I use it to power my positive ground pedals (GGG '60s FF, GGG Boutique Bender) with all of my other negative ground pedals?
Is anyone currently using a power supply similar to this for the same purpose?
Thanks,
- Buck
jacobyjd
Yeah, if it's isolated, you should be fine. Just make sure either your pedal's jack is wired right (center pin negative, barrel positive), and you should be fine.
