Help with GGG's Scrambler...i think i will become insane!
Started by gigimarga, October 20, 2008, 11:27:25 AM
gigimarga
Hello,
I've built an Ampeg Scrambler using the GGG's layout (some time ago i'd built one using Tonepad's layout, but it never works...my fault I think).
Because here it's impossible to find 2N5306 i used some MPSA13 (in Tonepad's i used BC517 with no luck), instead of BC169B i used a 2N3904 and all 5 diodes were 1N4148 (as i saw here: http://www.generalguitargadgets.com/diagrams/scrambler_sc.gif).
But...no luck at all...it sounds very clear with my Squier Affinity with the Blend pot at minimum...with the the Blend at maximum i hear no sound and after i move it a little i hear a clear signal too!!!
I boosted it using an original Boss Blues Driver BD-2 (which has a lot of volume) and i hear the Boss very clear  ;D
Are these 2N5306 so important??? Nothing can substitute them?!!
Using a 9.12V battery i have the next voltages, which seems to be OK as i saw in another topics:
Q1: C = 9.12     B = 4.33     E = 3.44
Q2: C = 3.53     B = 0.90     E = 0.24
Q3: C = 9.12     B = 4.50     E = 3.50
Q4: C = 8.77     B = 4.50     E = 3.50
Thx a lot all again!
My datasheets show the pinout for the 2N5306 as being ECB, and the MPSA13 as EBC.  Maybe that is where your problem lies.
Only three little pins, yet so many problems! :icon_rolleyes:
gigimarga
Thx again Mark for your answer...this is the layout that i used: http://www.generalguitargadgets.com/diagrams/scrambler_lo.gif...as you can see the pinout of the transistors is E-B-C, so who will use 2N5306 will must to wriggle them  ;)
The 2N5306 pinout I mentioned was for a Fairchild unit.  I do not know if the same pinout applies to all 2N5306 transistors in production currently or in past.
Whenever you make a circuit that uses discrete transistors, it is alwasy a good idea to keep the datasheets handy, and to check the pinouts of the transistors when you get no sound or get something unexpected.
gigimarga
I used MPSA13, not 2N5306...i relook at the schematic and they are positioned right  ???
Okay, that is one thing you do NOT have to worry about.
tiges_ tendres
Is your input getting shorted to your output somehow?
Try a little tenderness.
Make an audio probe and see where the signal disapears.
