Single Loop with Tuner Out
Started by NoGlory, October 30, 2008, 07:45:40 PM
NoGlory
First post here... :D
I want to build a single loop switch with tuner out... But I can't find a schematic or layout or something else... Who can help me?
Thanks in advance!
NoGlory
Evad Nomenclature
I guess you pretty much just want an A/B box?
1 side that you would send out to your tuner and the other to your effects and amp?
Evad Nomenclature III
Master of Dolphin Technologies
NoGlory
Not really, I want a Single loop w/ tuner out... so I can have my effects in the loop (no tapdancing and no tone suck when off) and a tuner out... http://www.loop-master.com/product_info.php?cPath=21&products_id=37 Like this one...
TIA
NoGlory
#3
I think I've found something: http://www.singlecoil.com/tb-strip/dia10.html
From Fulltone:
"There is an inherent problem with most A/B Boxes when running seperate effects for each channel.
Most A/B Boxes do not ground out the channel not being used, resulting in massive hum + hiss
when distortion or fuzz pedals are left on. This design eliminates that problem, and has the purest,
non buffered, most transparent tone available."
Could this be a problem here?
EDIT: to prevent 'plopping'/tocking (or so... :D) I can just solder 1M resistors over the poles of the jacks (all jacks?)?
NoGlory
mth5044
I can draw something up for you tonight, if no one else has answered.
NoGlory
Tnx, but can you have a look at the scheme I posted? Is it wrong/right? Any disadvantages or so?
mth5044
Yep, that looks good. Singlecoil is where I started when making true bypass stuff.
flo
Indeed, looks ok.
The "tuner switch" is an "A/B". 'A' goes to tuner, 'B' goes to the next switch.
Second switch is a "TrueBypass FX looper". There are several variants and this one looks ok.
NoGlory
Okey, thank you very much :d
About the resistors over the jacks for preventing tocking/plopping, just solder 1M resistors over the output and the loop jacks?
NoGlory
I drew something else, is it right?
mth5044
What are you trying to do there? If you are trying to redraw the original schematic, then you are a bit off.
NoGlory
I am not trying to redraw the original scheme... It is just another thing I drew where the inactive channel is grounded out (like on the Fulltone website)
It's based on:
and the original scheme...
Quote from: NoGlory on November 01, 2008, 01:42:20 PM
That looks fine. There's no need to take the sleeve connections back to the switch though, I'd just connect them straight the DC ground (- on your drawing).
flo
There is no need for 1M resistors over the jacks. To prevent popping, 1M resistors need to be placed on the input/output caps to ground, not after the switch.
NoGlory
Like this? Or ...? Don't get it anyway...  ::)
MikeH
If you can find a layout for a dual loop (or just take a single loop design and connect 2 together) just omit the return jack and it's connection to the switch and there's your tuner out.
The French connection
Hi! There's this:
http://www.diystompboxes.com/smfforum/index.php?topic=66411.0
just removed one of the loop and you're there i think...put your tuner in A or B...
Dan
I know, but the pedal i built does not boost...it just increases volume!
My picture files:
http://www.aronnelson.com/gallery/main.php/v/French+connection/
http://s193.photobucket.com/albums/z4/letournd/Pedal/
