ROG Tonemender ground question
Started by Bucksears, October 24, 2008, 11:18:08 AM
Bucksears
I'm thinking about using the ROG Tonemender as an EQ option for the ROG Thor and potentially another BSIAB II (replacing the BMP-style tonestack).
- If I use the Tonemender as an inserted EQ, do I connect the ground from the Tonemender to the ground of the circuit it's going in?
- Can I run the Tonemender from the same 9V source as the distortion circuit? (i.e. so I can use one 9V plug from my SupaCharger?)
Thanks,
- Buck
dschwartz
Tubes are overrated!!
http://www.simplifieramp.com
