Circuit diagram for Ibanez PH99 Phaser anyone?
Started by StephenGiles, October 30, 2008, 04:25:16 PM
StephenGiles
A friend of mine in England asked me for this, which I have never seen. Can anyone let me have a copy please?
StephenGiles
skiraly017
StephenGiles
Many thanks, that's a very nice drawing by Dirk there. has anybody noticed the 2 static phase shift stages and............a compander!!
The use of two fixed allpass stages is reminiscent of the MXR Phase 100, which uses 4 of them.  Interesting that the "intense" switch essentially selects between 2-fixed/two-swept and 2-fixed/4-swept.
The other thing that is not all that radically clever, but still something very useful that can be applied to many things using feedback, is the positive/negative feedback stage built around IC6B.  It is simply an inverting op-amp, with a pan-pot connected to its input and output signals.  In the middle position, it combines an inverted and non-inverted copy of the phase-shift signal such that they cancel each other out and result in no feedback.  Moved in either direction you get progressively more positive OR negative feedback from the same pot.
